Hijacker »
https://forums.nicoclub.com/hijacker-u9394.html
Fri Oct 30, 2015 6:14 am
You can check your fuel pressure to ensure the pump is properly working.
More than likely, you need to check your ignition. Did you use a pre-done swap harness like the ones from Wiring Specialties? Did you use the JDM harness, and if so, did you make the proper jumpers to power the coil packs? If you used the Black/Pink line through the battery tray plugs to power the Blue/Red ignition circuit, you could easily be having weak spark and a weak pump as that's too many big items requesting current. Normally people use the Black/Red ignition switched circuit to jumper to the coil packs, but the red can fade over time.
