SR20DET swap into a 02 Spec V??
For discussion of front-drive SR20DE, SR20VE and SR20DET engines!
joey83
I was curious if anyone has done this swap and if so what which sr20det engine i needed, because i know alot of them are rear wheel drive eqiupped!! And if i can use the 6 speed that comes in that car stock, i doubt it will bolt up but you never know!! if anyones got any info on this please help me out i really want to do this conversion even if its gonna be difficult!! Thank alot for all who help!!
adrianfromthecastle
Car: 1992 Nissan 240sx
there are plenty of front wheel drive sr20s. you got the nissan bluebirds w/ t25 and your pulsars w/ t28 and itbs . i doubt that your 6 speed would bolt up.
RED_DET
Vendor
2011 Infiniti G37x
Chevrolet Corvette Z06
For the FWD SR20DET you can go with a U12/U13/Avenir or GTiR. The 6sp transmission from the Spec V could possible work. Someone is making an adapter plate as we speak. You would need the wiring harness from an older SE-R for those motors to work.
joey83
ok so i wouldnt have to buy an sr20de engines 5 sp transmission!! well thats good news hopefully the mod on the 6sp works!! do you know anybody that has done this before and if theres anything more indepth that i will have to do to make it all work!! thanks for the reply
nametakennow
Car: '06 MINI Cooper S
There is an SR20DET with a Spec V 6spd. The adapter plate maker is a member, I think he goes by Trav4011.
Return to “SR20DE / SR20VE / SR20DET Forum (front drive)”
