sr20det swap into 89-94 240sx
240_slida
Car: 92 civic hatchback with full gsr swap
okay my question is does anyone have a wiring diagram of how to do it and does anyone know if the s14 and s15 ecu will plug right into the stock 89-94 ecu harness.......and also do i have to upgrade the drive shaft and will the sohc 89-90 cluster read th engine just as fine as a 91-94 240sx..all help is needed thanks.......
homeslicej2
Car: 1990 Nissan 240SX S13 SR'd hatch
Check the SR engine subforum out and try searching as well. There is a sticky at the top of the SR page that has links in it to wiring how to's and install advice. There should also be threads about S14 and S15 motors into the S13 chassis. S15 motor is a bit different and will require mods to fit. The S13 and S14 SR's fit into the S13 chassis, but need harness re-wiring to work. You use the SR ECU and SR harnesses for the motors, but have to re-wire some stuff to hook everything up. 89-90 tach will have to be replaced. The SR can't drive it properly. you'll need a 91-94 tach for it to work (this is for an S13 SR into the 89-90 chassis). Anyway, do some searching and you'll find what you need.
