sr20det swap info-sticky?
quiksilvia
Car: 95 s14 se
although the question of how much is needed to swap a sr20 into my 240 is asked a lot we dont have a sticky for it, so ill try my best to lay out all that is needed and how much it'll cost you. my experience is from putting a redtop into a s13. if u have a 89-90 240sx: besides the motor, you'll need the power steering lines from a 91-94 ka24de 240sx, and the ac compressor. if u dont want either of these to function, then obviously u wont need them.THE SWAP. prolly the best way to go would be to get a complete front clip from a reputable distributer, http://www.srswap.com http://www.venus-auto.com phase 2 mtortrend and a few others. but ebay can be a problem, and its usually more expensive for the clip. a clip will come with the motor, ecu, wiring harness, everything under the hood, and the transmission. the transmission bolts up to the stock driveshaft of the 240 and the motor drops into the 240 engine bay with no mods. if u just get the motorser, engine and transmission, sometimes ecu and harness if ur lucky, u will need many other parts to finish the swap, ie: ignitor chip, maf, coilpacks sometimes, etc, it can end up costing more and u will have to find these parts costing time, so just get the clip. on my clip, i had no downpipe, but many places stock these for around $130. heavy throttle also sells ez install kits with new hoses, and tune up kits, with new plugs, oil and fuel filters, and belts. some people argue that gasget kits should be ordered and installed to replace all of the gaskets on the motor while its out and easily accesible, these run around $250. i also got a walbro 255 lph fuel pump as the stock 240 one will only work under stock boost, if its in good shape, i got mine for $100 shipped, off ebay, brand new. so lets recap:sr20det redtop front clip......$2000-$2500install.........$1000-$2000 depending on ur year and what the shop charges.fuel pump....$100gasket kit ......$250downpipe.....$130if u want u can buy the front clip and have a shop do a harness service for about $100, they take the ka and sr harness, let them mate and u have a plug and play harness. otherwise u have to modify some plugs, this can be found also on http://www.srswap.com under faq-wiring. so ur looking about $2500-$3000 to do it all ur self, but its always a good idea to have some extra cash just in case, and for any unforseen problems.http://www.sportcompactcarweb.com did a write up of their sr swap, its not too extravagent but its a good basis for you to start. srswap.com also has a lot of info for the swap. most of all your other questions have prolly been answered, use the search button, it is your friend. if i have forgotten something, go ahead and add it on.
BuudWeizErr
jesus dude, if you want to sticky something at least type it up in english.
quiksilvia
Car: 95 s14 se
sorry ms. vaughn
slw240sx
Car: 1990 Ca18det 240sx Hatch
haha your section has no moderators to do this !!! just like us over in the CA section!
GraySilvia
Car: auto-x, drag racing, beer
quiksilvia wrote:sorry ms. vaughn
"That Veronic Vaughn is one piece of ace...i know from experience dude."
quiksilvia
Car: 95 s14 se
YOU KILLED IT! trust me dude, i know from experience. no you dont. well, not me personally...but a guy i know...him and her got...it...on. no, no they didnt. well...no, they didnt. but you can imagine what it'd be like if they did, huh!
MojoMan
Car: working on cars and women
EVERBODY, ON THE BUS AND NO YELLING!
quiksilvia
Car: 95 s14 se
odoyle rules, back to my thread....
Mameluke
"S13 Red Top SR20DET complete $2500 plus shipping. Includes all electronics and ignition parts, uncut harness, transmission, warranty and tech support"
isnt that all i need?? besides that fuel pump to replace the 240's.
Mameluke
althou id probably want to get the tune-up kit $40 and the base install kit<< is it realy necessary?
quiksilvia
Car: 95 s14 se
not really, but to replace old filters, and new plugs, just so you know that your car is running smoothly, these cars are more than half the time beat to hell in japan, and the esz install kit just gives u most of the hoses, clamps etc that u'll need so that u dont have to keep running to autozone every 5 minutes
spec-v5150
and you DO NOT need the PS lines from a DOHC. You can use the SOHC. That is some money saved.
Samabra
Car: Modding cars
Sticky Icky icky....oh wee...... put in the air
badass240sx
Samabra wrote:Sticky Icky icky....oh wee...... put in the air
Muaha :bonghit
Gladius
Stop staring at me swan!!!
skitzo
Some other things to consider are:
Clean the SR when its outside the car and clean the engine bay when you pull the KA -- im not sure of the best way to clean it really.
Clutch condition, you may need a new one ~300
fuel filter from a 300zx (just go to a Nissan dealer)
belts/hoses
thermostat, cheap part, not a bad idea to replace it when you do the install $25
Make sure you inspect the oil pan for dents
inspect all gaskets, etc.
-Remove the stock SR AIV solenoid and weld the recirculation port off the turbo O2 housing shut OR you can buy a plug for about $10
I've heard you need to switch the speed sensor from the KA to the SR transmission, not sure on this one.
quiksilvia
Car: 95 s14 se
YOU DO NEED THE PS LINES, or u can take the sohc ones and make some new ones and fabricate...the fuel filter comes in the tune up kit and the hoses and belt too, and i havent heard the speed sensor thing...
MojoMan
Ya do.
Mameluke
beat to hell eh.. well lucky for me , i just looked inthe paper today (buysell ;western canada classified) and found an ad for a place that imports jdm engines. they claim to have it all hopefully ill chek it out soon. and the complete red top engine is about 275 bucks (usd) cheaper than heavythrottle and others.
btw, since most are beat to hell, then anyone who gets an sr is takin a chance.
quiksilvia
Car: 95 s14 se
chance is right, but a complete redtop for 275? ur gonna need a billion misc. parts and half u wont be able to get. if it sounds too good to be true, then it is. did u forget to add a 0 after the 275(0)
Mameluke
275 bucks CHEAPER than heavythrottle which is 2500 i think. so this place is actuall 2250 bucks for a complete red top. thats 3000 canadian dollars.
Mameluke
but its a bit safe for me cuz its a local place maybe they will allow to do some tests to the engines i dono i can chek it more throoughly..
quiksilvia
Car: 95 s14 se
ooooooooooooooooooooo, i gotcha. thats not bad, i got mine for 2 even. is this a full front clip?
Mameluke
no its not a front clip, but its got the motor/tran/ecu/ ignition krap etc, changeover thing
quiksilvia
Car: 95 s14 se
ok, i got a full front clip for 2, which is why those other places might have been more expensive, plus ht and enjuku have a reputation so u know ur getting quality stuff
Mameluke
thats true, you got a pretty good deal then eh nice..
quiksilvia
Car: 95 s14 se
in this months' superstreet, the tech section had a question about the speed sensor thing, if u use the sr transmission and the sr gauge cluster then u will be ok, but if u use the ka gauge cluster then u need to put the ka speed sensor in the sr transmission, they said it should take about 30 minutes
Mameluke
where can i get a silvia gauge cluster besides a front clip
quiksilvia
Car: 95 s14 se
ebay, venus-auto.com, all kinds o places. if they sell the sr, they prolly have the cluster
SpeedRacer1
Car: 1990 240SX, G35
MojoMan wrote:Ya do.
NY S13 SR wrote:Update: both S13 speed sensors are the same JDM or KA, we have interchanged many of them. If it fits and has a red gear it will work.
Jeff HHeavy Throttle Performance
Also, if you get the JDM PS lines and are a sneaky guy, you can make them work.
