Geno750 »
https://forums.nicoclub.com/geno750-u48799.html
Sat Feb 24, 2007 11:19 pm
Your questions are very vague. First, if your just revving the engine at idle you won't build very much boost, and the bov won't open so I wouldn't worry about that one until the car is on the road.
"Some kind of leak on down by my turbo... and has some an oily substance."
This is obviously some kind of oil leak, but you are not specific as to which pipe you removed. If it was the hotpipe, I'd say your turbo's seals are leaking and your turbo is bad. If its the intake pipe, maybe you sucked some oil out of the head. For better answers be very specific in your description, and include pictures if at all possible. Hope this helps.
