apex240 »
https://forums.nicoclub.com/apex240-u57348.html
Tue Apr 17, 2007 10:36 am
I have never experienced an SR20DET before but why does my KA24E (early high compression engine) seem to have been way faster? The acceleration just seems lazy to me. I was able to get up to 160 KM`s on a straight where I could have gotten to 180 with the old engine. After 4,500 rpm there seems to be a drop off in acceleration and from a stop it doesn`t feel like it could even spin the tires unless I side stepped the clutch at 3000 rpm. I am running the stock intercooler and boost solenoid but have a K&N cone filter and high flow exhaust with stainless high flow cat. I ditched the egr solenoid and capped off that vaccum line and still have the charcoal canister hooked up. I put new NGK irridium plugs in (BKR6EIX), new thermostat and oem oil filter 300zx TT fuel filter and walbro fuel pump, a new aftermarket maxima clutch and pressure plate with KA24E throwout bearing. (I removed a three puck racing clutch and pressure plate) I also resurfaced flywheel. I want to run a little more boost when I am sure everything is working right and have a boost gauge and manual boost controller.
Modified by apex240 at 1:49 PM 4/17/2007
