just finished doing a sr20det in to a 1990 240sx on my own about a month ago. if your getting a front clip your pretty much set as long as every thing come with this. it all depends on what you plan on doing to the car but if you did what i did and just bought the motor and transmission and keeping it stock for now your going o need a few things.a radiator from the s13 witth the sr20det if you plan on using side mount inter cooler cuz the hot pipe gets in the way i just upgrade to the koyo radhot pipe cold pipe side mount intercooler if your not using a front mount intercoolerdown pipe with 3ich exhause recomendedre route your heater core linesre wire cut and extend you wiring harnesshttp://
www.frsport.com/SR20DET....htmlthats the site i used and it worked for merad hoses for new radmay need a walbro 255lph fuel pump depending on the life of your exsisting one i havnt need a new one yet for my carif its 89 or 90 240 and you want power steering youl need a non hicas power stering pump from the dohc ka24 and lines as you go along doing this swap you may run into different things depending on what come with the motor and what upgrades you deside to do
if your doing suspension stuff you need t know what kind drivin your gonna do weather is drift track drag or what ever you plan on doing one thing that makes a big diffrence that no one really thinks of is polyurithane bushing for all around your car thaey say to replace them after 10 years and even if its not there better then stock any ways. also id get strut bars and sway bars. id also recomend changin the diff to some thing better then whats in the 89-90 240sx because the one tire fire suckhope that helped you out a bit thats all i coule thin of off the top of my head and good luck
