sr20det suction kit
jr.
Car: nissans x 7
my engine didn't come with the factory kit or anything for that matter, I need to find a kit but it seems every one I find is for the z32 maf. can a kit for the z32 maf be converted to work with the stock maf? or,, what other options do I have?
Kalypso
go to a muffles shop, or an autozone: get some pipe, rubber fittings, a K&N
filter, and make something.
slow s13
Car: cars, photo, music
Hijacker
Car: '92 240sx Convertible
'94 F-150
Wow....80 dollars for about 20 bucks of parts...
duffman1278
Car: 89 240sx Hatch, the wildcats!
Dude I got mine for 25$ shipped from this one guy off the forums, but all he did was get some pipe, and had it bent. You might be able to see it in this pic. It was just one piece made.
positron1
Car: Project: 1993 Nissan 240SX Coupe SR
Daily: 2010 Honda Civic Coupe
Man your bay is so freakin' clean!
positron1
This is the part that I thought I was buying off ebay a couple of weeks ago and when I got it it turned out to be some of that cheap "Spectre" ricer piping from AutoZone...sent that ish back and decided to stick with the stock rubber!
adrianfromthecastle
Car: 1992 Nissan 240sx
positron_ wrote:Man your bay is so freakin' clean!
frekkin tell me about it... aluminum Koyo rad and not even 1 crack on the resoviour?
Hijacker
'94 F-150
This is clean V
J/k
That's a much better price, Duff. Was it crush bent or mandrel bent? I can't tell what kind of MAF you're running either. Z or SR? If he swedged the end of your intake pipe up for the Z MAF, that would be awesome!
When I put my new S15 T28 on, I'll have to swap to a metal pipe I think since I'll be swapping to a Z MAF as well. Also, my rubber tube did collapse. Thanks Nissan! -_-
jr.
Car: nissans x 7
thanks for the input. I considered the parts store piping route, i just got to go ahead and do something. another question. whats the difference between a stock maf and a z32 maf suction kit? would it do me better to go ahead and upgrade to a z32 maf? Thanks!!
Hijacker
'94 F-150
Zs use a 3" MAF outlet and SRs have a 2.5" outlet IIRC.
jr.
Car: nissans x 7
Hijacker wrote:Zs use a 3" MAF outlet and SRs have a 2.5" outlet IIRC.
can I just adapt it? would that present any problems?
positron1
So, overall, it would be better to replace that stock rubber intake piece...if you can?
Clawhammer
Don't you need a tune if you switch to a z32 maf?
duffman1278
Hijacker wrote:This is clean VJ/k
Its an SR MAF, I don't have use for a Z MAF at the moment. But as for the bending I'm not sure which method he used to have it bent, I just bought it as is.
And yes clawhammer, you do need to have the Z32 one tuned for the SR.
duffman1278
adrians_s13 wrote:frekkin tell me about it... aluminum Koyo rad and not even 1 crack on the resoviour?
lol, yup, no cracks on the resorvoir. Still original.
Hijacker
'94 F-150
Clawhammer wrote:Don't you need a tune if you switch to a z32 maf?
Yeah. I'm also doing 50 lbs injectors at the same time I upgrade the MAF and ECU. Get it all done in one step
jr.
Car: nissans x 7
can I make this work with a stock maf? if so would there be any draw backs?http://cgi.ebay.com/Nissan-240...0.m14
