94hatchsr »
https://forums.nicoclub.com/94hatchsr-u283619.html
Sat Jun 02, 2018 11:28 am
Okay, this has been puzzling me for a few weeks. I will go into detail over everything I've done so far. I'm not sure what the problem is. PLEASE READ ENTIRE POST
1994 180sx with a built SR20DET redtop swap. Top mount, big turbo, Apexi FC, aeromotive 340lph
When I first start the car from cold it starts up no problem and runs excellent. No noises, no issues. If I wait about a minute, OR I try to give it some gas the engine will bog and start to run like crap. It SEEMS like when it goes into closed loop it will run poorly?
If I try to apply consistent throttle it will rev up but it sounds like an ignition cut rev limiter almost.
I've checked the fuel pressure, tested the MAF, tested the CTS, tested & replaced the TPS, checked the plugs, checked the coils.
I found the TPS sensor to be bad and reading 5V all the time so I replaced that to a working unit. Sypmtoms have improved but not much.
I used the power FC to check sensors and it looks like everything is reading right, except I am not getting a reading on the O2S. I tried disabling o2 feedback from within the power FC and nothing changed.
I honestly have no idea what could be causing this right now especially cause when it first starts it runs perfectly and then starts to get messed up.
Any ideas? TIA!
