drkidd22 »
https://forums.nicoclub.com/drkidd22-u66958.html
Fri Jul 30, 2010 5:43 am
So here goes the story that's happening to me.
I have 240sx with SR20DET and the transmission is stuck in 1st gear. With the car ON/OFF all it shifts into is 5th. Shifter moves side to side fine. I can start the car and run it in 1st gear, but if I try to shift into 5th it starts to grind. So because I can push the clutch pedal fine and it releases ok I think the clutch might be good, or maybe not. I'm not sure what's going on with it, any advice would be appreciated.
Jose
