The motor is in what type of car?
What ECU are you using? remapped JWT ECU, your cars OEM ECU, JDM ECU that came with motor?
What MAF are you using, your cars OEM MAF, MAF that goes with JDM motor?
I understand that it is an imported sr20det, since they weren't made over here. But there are several different types of motors. Example: Its either a Bluebird, Avenir or GTiR motor. Which one?
Read the Turbo FAQ, it gives a detailed description of each motor.
zerothread?id=94868 scroll down about midway.
What type of o2 sensor are you using? OEM?
Need to know the answer to all the above questions.
