sr20det speed
scottsnissan
Car: 1995 240 sx se
I have a s20det black top s13.Stock trans and rear end on S13 body.I was wonder since i ahve no speedo what speed should i be at in fifth gear.
EX.5th gear 3000rpm = speed ?And so on jus the primary nuber like 45 55 and 70 mph
virus77
Car: 95 S14, 71 240z, 97 e320
it will be around 73 mph give or take a few. thats 3000ish in 5th gear. its the only one I remember off hand.
275/35/18 with J30 rear end. Ive tested my car against a radar and my speedo was pretty dead on.
Modified by virus77 at 4:02 PM 7/25/2005
scottsnissan
Car: 1995 240 sx se
wow then i have a prob. From having my lil bro driving beside me 3000 was around 65 mph i belive if not less. I guess me rear is starting to get bad.Or jus my transmission.
Re_Joshua
Car: 1989 240sx hatchback (SR)
Yeah me too, at around 3k im sitting around 60-65 mph....
Turb0wned
at 60 im at 2500... maybe the j30 lsd makes a difference... i dont know but i have one
Nismo_Freak
Car: 89 Nissan 240SX
Tire diameters also play a role.
sr20detmaybe
Car: 95 240sx
WEll the j30 has a different gearing than the stock 240sx one so it will make some difference.
PROJECTRB240SX
Car: 1972 DATSUN 240Z W/ SR20DET
3.9 REAR END AND 205/50R15 TIRES, I CRUISE AT 3100RPMS AND THAT IS ROUGHLY 75MPH.
ETTInnov04
Car: 1989 Nissan 240sx fastback
I'm at about 70 at 3k. Drivetrain is as follows:Stock open diff.stock sr trans205/55/16 s14 wheels
Modified by ETTInnov04 at 12:26 PM 7/27/2005
scottsnissan
Car: 1995 240 sx se
Srry my tire size is 205/40/17.
PROJECTRB240SX
http://www.geocities.com/z_design_studio/
SR TRANS RATIOS ARE....1: 3.3212: 1.9023: 1.3084: 15: .759
STOCK 240SX DIFF RATIO IS 4.08MY DIFF IS 3.9
PROJECTRB240SX
BTW TYPING MY INFO INTO THAT CALCULATOR LEADS ME TO BELIEVE I NEED TO GET MY SPEEDO CALIBRATED.
scottsnissan
Car: 1995 240 sx se
srry but the link is not working correctly
PROJECTRB240SX
WHATS NOT WORKING?
scottsnissan
Car: 1995 240 sx se
When i click on it (the link u have posted)It shuts down all my eplore windows.So duno if its my end or not.
PROJECTRB240SX
WHEN I CLICK ON IT, IT GOES THROUGH. LET ME TRY AND FIND A DIFFERENT ONE.
PROJECTRB240SX
HERE IS A LITTLE BETTER ONE: http://www.f-body.org/gears/
JUST USE THE TRANS RATIOS I GAVE YOU, WITH WHATEVER TIRE SIZE AND REAR END (AXLE RATIO) YOU HAVE.
DrifterProdigy85
Car: 1989 Nissan 240sx (Zenki Onevia)
70mph at 3000rpm sounds about right for me. Its crazy that the SR can go out to 170+mph.
PROJECTRB240SX
Well that doesn't take into account for drag, friction, gravity, etc.
Re_Joshua
Still it's a pretty cool little website. Now I know I really want a new rear end, hehe.
DrifterProdigy85
Scott from Enthaply tuning has a 500+ rwhp SR that hes gone 180+ at over 8000rpm. Not sure of the exact numbers but its F'in crazy that he did it.
I plan on getting a 4.36 rear gear for my car to cut down on the top speed while gaining alot of acceleration.
PROJECTRB240SX
and less low end traction.
pgt892
Car: 1997 240SX
It's a little lit but I am around 70 at 3k in 5th. What are you guys at in 5th at 4k?
Re_Joshua
Never really paid attention to the 4k mark...speed limits around all these back roads are 55mph...next time I take it out I'll let you know.
