sr20det specs
kendal_jones101
Car: 91 240sx
ok i have an sr20det im building iam about to order the enjuku racing bottom end package but i cant find info on the rod,crank and thrust grades my motor is still in my 240 are all the rwd sr20 gonna have the same grades and specs cause i need the rod bearing grade crank bearing grade and thurst washers grades before i can order everything
Hijacker
Car: '92 240sx Convertible
'94 F-150
http://www.240edge.com/manuals/s14_sr20det.pdf
Google is hard to use, I know. And for determining bearing grades, I have it listed in my motor rebuild how to (which is conveniently linked in my sig and the RWD SR FAQ)
V8slayr
Car: 97 240sx
You need a FSM and to take your motor completely apart. There are #'s on the block/crank that correspond to what you are looking for. Just follow the service manual and you'll be fine
