SR20DET Specifications
240Knightrider
Just in case anyone was wondering
Specifications for RED Top SR20DET 180SX 91-93 and Silvia 91-93 Displacement: 1998cc (2.0 liter) Cam type: DOHC 16 valve, chain driven cam sprocketsBore and stroke: 86mm x 86mm Compression: 8.5 : 1Horsepower: 205ps at 6000rpm Torque: 203 ft/lbs at 4000rpmStock boost: 7 psi Throttle body bore: 60mmTurbo specs: Injector size: 370cc/min Compressor: T-25, 60 trim 56mm BCI-1 compressor. Turbine: T-25, 62 trim 53.8mm 0.64 A/R turbine housing. Center Section: Journal bearingsPerformance: The stock turbo will be safe to 13-15 psi. After that, the turbo is past its efficiency range, and power increases will fall off and are not worth the risk of turbo damage. The engine should produce 230-250 RWHP at safe boost.
Specifications for Black Top SR20DET 180SX 94-98Displacement: 1998cc (2.0 liter) Cam type: DOHC 16 valve, chain driven cam sprocketsBore and stroke: 86mm x 86mm Compression: 8.5 : 1Horsepower: 205hp at 6000rpm Torque: 203 ft/lbs at 4000rpmStock boost: 7 psi Throttle body bore: 60mmTurbo specs: Injector size: 370cc/min Compressor: T-25, 60 trim 56mm BCI-1 compressor. Turbine: T-25, 62 trim 53.8mm 0.64 A/R turbine housing. Center Section: Journal bearingsPerformance: The stock turbo will be safe to 13-15 psi. After that, the turbo is past its efficiency range, and power increases will fall off and are not worth the risk of turbo damage. The engine should produce 230-250 RWHP at safe boost.
Specifications for Black Top S14 T28 VTCSilvia 95-98Horsepower: 220hp at 6000rpm Torque: 203 ft/lbs at 4800rpmTurbo specs:Compressor: T-28, 60 trim 60 mm BCI-1 compressor in T-04B housingTurbine: T-25, 62 trim 53.8mm 0.64 A/R turbine housing.Center Section: Ball BearingS14 SR20DET's use a different ECU and harness, these are extremely expensive and hard to find. Variable valve timing system and a different turbo are the significant changes from the S13 SR20DET engines. S13 uses 'low port' intake design vs. S14 'high port' design. Performance: The stock turbo will be safe to 13-15 psi. After that, the turbo is past its efficiency range, and power increases will fall off and are not worth the risk of turbo damage. The engine should produce 250-260 RWHP at safe boost.
Specifications S15 Black Top SR20DET S15 Silvia 99-Horsepower: 250ps at 6000rpm Transmission: 6 Speed, Close Ratio Injector size: 480cc/min Turbo specs:Compressor: T-28, 60 trim 60 mm BCI-1 compressor in T-04B housingTurbine: Inco turbine wheel. Cast divider wall between turbine discharge and wastegate.Center Section: Ball BearingThis engine is expensive and hard to get. If you are on a tight budget, please consider other options.Additions: 6 speed manual transmission. The 6 speed cannot be used on the S13 and S14 motors, and uses a different driveshaft. Speed sensor is located in the differential.
240Knightrider
What the hell is driving moms car under my user name does anyone know how to get ride of that or is it part of being a new member cause I dunno. Thanks
civics91
Car: cars,cars,cars
you need more post get to work
912.0turbo
uhhh....Thanks for the info but we already have that information on the stickys.
