nissanjunkie4life »
https://forums.nicoclub.com/nissanjunkie4life-u208703.html
Wed Oct 31, 2012 10:26 pm
No, lent my compression gauge to a buddy and have just been busy. It seems like its progressively getting better (its getting cold so that might have something to do with it). Also when it is smoking it mostly does it when i take off (like from a redlight) and gets worse in stop and go traffic. Have also ran into a new problem, i was running some s15 440s and 2 of them stuck open while on another car. I bought a set of deatschwerks 370s and my car is running lean, to the point where its breaking up at low rpm, swapped in a set of factory 370s and noticed no change... motor is all factory and was running fine with the 440s. Thought maybe there was a ecu tune for the 440s but #62 is untouched. Factory fpr, z32 filter, no kinked lines, pump is priming, all orings on injectors are new, and its doing it with both sets of my injectors so what else do i look for? Im running open dp so wideband is gona be off some, but its not even reading on my aem so its like 17+ afr. Iv noticed if i hit the gas and let off the afr will bounce down to like 13s and then right back up if that matters. Any help is appreciated
