SR20DET same specs?
GripR
Car: 92 miata
I tried using the search engine to find out what the specs of the sr20's were but I only found threads that had info about different oil squirters, turbo's and injectors and so on.
What I would like to know is are all the SR20's the same specs in such as valve clearance, crankshaft journal tolerance and etc.. I plan on rebuilding my SR next year and I want the specific specs for it.
So are the red/blacktops S13/S14/S15 the same (internal specs)?
xero1
Car: 08 Altima Coupe
sr20det have hydraulic valves, so you don't need to adjust valve clearance.
