itsnever2fast »
https://forums.nicoclub.com/itsnever2fast-u43601.html
Wed Jun 27, 2007 2:52 am
the one piece s15 6 speed into S13 driveshaft is $349 through driveshaftshop.i still need to do a little research but i am pretty sure an s15 trans can bolt up to an s13 motor with an s15 flywheel... the clutch is the same, flywheel is different. i know the input shaft is further in the trans on the 6speed..ideally, buy an s13 motor, upgrade the turbo, drop in some cams, then swap in an s15 trans, you will need an s15 flywheel too. good S15 motorswaps are overpriced IMO ($4,000-4,500). if you dont want to go crazy built in the future, get the s15 swap. but an s13 motor is cheaper to build. the head flows better too when you start to modify.
Modified by itsnever2fast at 6:11 AM 6/27/2007
