SR20DET S14 or S15 How do I tell the difference?
silviadad
Car: 89 240sx coupe, 92 240sx hatch
Hello all,New to this forum and hope someone has some answears for me. My teenage son and I are doing the SR20DET swap into a 92 hatch. I bought the SR engine, transmission and harness from a guy locally that gave up on his project. He purchased it from someone on eBay and purchased it as an S14 kit.The engine is in and running without any problems. We know for a fact that the engine is not an S13 but some of the S14 parts are not working on it either.
Here are my questions on the S14 or S15 engine and why.
1. Neither of the Sentra oil filters for an S14 (Fram PH4386) or S13 (Fram PH3682) will fit on this engine. The thread diameter and pitch of those filters will not match with the housing threads on the engine and the S14 filter (sentra Fram PH4386) has to large of an o-ring flange diameter to seal on the flange even if the threads were correct. We found that a Fram PH6607 is the correct thread pitch and O-ring diameter.
The filter that was on the engine has a part number 15208-65F00 and that I'm told is an S14/S15 filter???
2. The Power steering pulley and crank pulley are 3 rib. I was under the impression that only S15 engines used the 3 rib belt???
3. This engine has no visable sign of ever having an EGR valve or system like is shown in the JDM S14 service manual. Should it not have been so equipted????
4. The transmission is a 5 speed but did not come with the engine when the local guy bought it so that rules out the 6 speed test.
I tried to find a serial number date code reference for the engine online but had no luck. The SN is 257258.
I have some driveshaft questions also but figure I may need to start another topic for that. I'm going to throw them on here just in case someone can help.
I'm making a one piece steel DS for the car. The car was an auto and the joints were junk anyway. The rear flange, yoke and U-joint are no problem. I was able to get the correct replacement u-joint at autozone. I have the transmission yoke and flange that came with the JDM transmission but it was cut off so I don't have a complete DS.
The rear u-joint is smaller than the front. I checked at autozone and my guy there says the u-joint for front or rear, S13 or S14 are all the same.
1. What is the correct front u-joint for a JDM 5 speed transmission yoke????
Thank you
seang
Car: Ford Fiesta ST
SR forum...zeroforum?id=138
silviadad
seang wrote:SR forum...zeroforum?id=138
OOPS.
I moved it. Thank you.
