Parts:
Bronze Guides In shop
Stainless Valves 0.5mm over size in/ 0.5mm oversize ex with reduced valve stem dia of 6mm In Shop
Titanium retainers In Shop
HKS 264 intake and 264 Exhaust Cams IN SHOP
Performance Valve job in process
new valve stem seals in process
rocker arm stops in process
Here is the new exhaust valve vs. the old one
Here is a picture of what the stock exhaust valves look like in the head
and this is with the bronze guides in and stainless 6mm
Here are pictures of the differences between Stage 1 and Stage 3 porting, on the left side of the port is finished the right is where it was before and the secound pic is completed.
Here are pictures of the final job on the exhaust, it's a done deal
Here is the finished porting product I put out. You can see the exhaust ports in this picture.
Time to cut the seats, resurface, cleaned and assembled
