sr20det s13 Turbo..HElpp!
arlrat
Car: 240sx 1991 sr20det
im new to da whole sr its a redtop
i thou i had a blown turbo bc my car smoked and i saw oil well i took tha turbo out and swaped in a new t25 i connect the whole oil lines and everything in rite place
but idk why i started da car nd it smoked alot nd then smoke was coming from turbo and it was oil when it touched the down pipe so idk wat da problem is if its da turbo or maybe the head gasket i really dont knw
imma but some turbo gaskets nd try to work on it agaiin i will love to get some help i wanna knw wats really da deal... ITs drippin oil and idk why or were from!
please help i feel like givin up on it :(
USMCgetsome
Car: OWN S13.5 RB25DET/2003 G35
make a video and post it up. is it white smoke or bluish grey smoke. What does the smoke smell like?
arlrat
Its white smoke.. And it doesn't smell .. Idk why is there an oil everywhere
Sugar
Car: S13 w/ Sr
So it smoked out the exhaust before? And now it smokes off the turbo itself?
Write out your exact problem, use real words and punctuation. I can hardly make out what is happening.
The turbo could have been bad before and now you just have a loose line on the new turbo? Unless its still smoking from the exhaust?
Is it a new turbo, or a different turbo? New parts are usually coated in fine oil, it will take 10-30 minutes to burn off.
Where is the oil dripping from?
We can't lead you in the right direction if we can't make out what you are saying. :dblthumb:
PyR0NiAk
Car: S13 SR W/ T2 GT3071R .86AR, JWT S4 Cams, 810cc Injectors,Z32 MAF, JWT tuned ECU 87mm 9:1 Compression CP pistons, Manley Rods
:werd:
