S14Jer »
https://forums.nicoclub.com/s14jer-u105909.html
Mon Sep 22, 2008 4:47 pm
Ok, here is what happened
I was on the freeway merging on, I was in 2nd and I punch it and after building up boost at around 4k rpm I hear POP. I blew a pipe off the FMIC, car dies I pull over and reconnect it, no big deal I thought, drove the car home.
A few hours later I get on the freeway to go home again, the car is running decent but then it starts hesitating and chugging at low RPMs in 5th. At idle the car seems to run really rough and there is black smoke coming out the exhaust. It seems if I am at higher RPMs the car will not hesitate or bog down but it also seems random. Sometimes itll ide fine and then itll be right back to bogging.
Anyone have an idea? Im no mechanic but I know a little. I was thinking possible it could be my MAF or spark plugs?
It only happened after I blew the pipe off the IC, that has to be the cause but what do you think caused that to happen? I need to get home from Chicago to Michigan tomorrow. So please give me any info you can think of, thank you all.
