sr20det Running Hot
james-dean85
Car: Nissan 240SX
I have a sr20det in my 240sx. It was runnning around 190 and then when it started getting hot outside, it ran up to 215-220 and if it sits it'll go to 250. I was wondering if this is normal or in the temperature range it should be running? And if it isn't, what type of things should I be looking for to get the temperature back down?
Paul
EfiniRX7
Car: 93 FD3S not going anywhere, 2003 E46 M3 traded, s14 sold, 2010 camaro sold, now another kouki s14, FD did go somewhere, Now a 535whp rotary Kouki s14
What kind of radiator do you have? My stock ka radiator is not enough for summer temps, so I parked mine for now.
james-dean85
Car: Nissan 240SX
Koyo
schanne
Car: 93 Hatch-Sr20
I think 250 and your screwed. My runs at 190-205 in Florida. Are your fans running at all? Are you using the stock crap fan?I use that metal air panel you can get for cheap.Water wetter (red line)Bleed system really really well!And a koyo you should be good. If not you probably have other problems.
EfiniRX7
Your head gasket might be dead? You should try a cooling system pressure test.
