sr20det runing rich
scottsnissan
Car: 1995 240 sx se
Srry to make a new post but eaiser to do it this way.
Well here it is cars running rich.We wanted to see how bad so we decided to put in a new set of plugs drive 5 miles and test.Well the results were not so good.Plugs look like they are 4 mths old .Bad 4 only 5 mile ride.We are trying to solve this and this is what we tried so far.
1.ECT WAS REPLACED.and wires were tracked with no breaks in.2.Mafs was changed.(90 ka24e)3.Fuel pressure tested(46 without vacume and 38 with.)4.Timing was checked with light .(Ran smoother on top dead but was hard to tell with the idel being jumpy.) was done according to fsm.with plug wire5.Checked o2 sensor.was all good.6 Ran codes on ecu .Got 12 so we replaced and never had another(jus 55)7.Injectors firing.8 checked coils by pulling them leaving plug in and starting car one by one fire at the plus was strong.
Thats what we have done so far and nothing helped(except new plugs but they fouled so quick was long.)
the next step is pull injector rail and check o rings and Find a ecu some one will let u place in car so i can rule that in or out .So please help need this car running
Motor is stock 100% including smic.#62 ecu S13 balcktop3"elbow 3"downpipe,3"test pipe"3 inch cat back system.Koyo alum rad.Eletric fan
aim name chvybeatsfordEmail [email protected] 225 573 3089
Jus really looking for a test ecu for now.and any help .
grey_240sx_man
Car: 1990 240sx coupe
Is your ecu plug completely in. I had to zip tie the outsides of mine because they were bowed out. Acted like your car did until I zip tied it.
scottsnissan
Car: 1995 240 sx se
i can send u a pick let me know if ur looked like this send aim to chvybeatsford ill be I need some help.
scottsnissan
Car: 1995 240 sx se
pics i cant get them on one page so bare with me i dont know how to do that
scottsnissan
Car: 1995 240 sx se
scottsnissan
Car: 1995 240 sx se
biglipzit
Car: sr20det S13 RHD 200SX
none of the pins in the ecu are bent or broken right? That could cause probs like that.
Taylor_Durdan
god that harness looks awful..no wonder youre having problems. let me redo it, please!
scottsnissan
Car: 1995 240 sx se
yea u telling me like i said the guy had no clue what he was doing and about how much would it cost to redo.
Taylor_Durdan
it depends on how bad he's got it. im going to say in the 250-300 range though
daz1320
Car: '93 vert
try a e5 ecu.my blacktop ran like sh!+ when i was using a 62.
Turb0wned
did u check ecu codes?also i know its hard to believe sometimes but its prob a leak some where.....
other than that get an S-AFC and ur running rich prob can be fixed
scottsnissan
Car: 1995 240 sx se
there are no codes ,Were in the process of leak down ,Buddy brought intercoller to test today and checked all piping no tears or anything so either Smic ot on turbo itself.
Whats S-AFC
TunaFish
You check your temp sensor, or for boost leaks?
scottsnissan
Car: 1995 240 sx se
checked temp sonsor and wiring ,Boost leaks we are limited to at home test so like i said pulled smic to test it at friends shop the rest will have to wait till i can dare drive it again .
Any easy way to test ill would be app of.Lil tricks and places to look also .
bentsprocket
Hey, I hope you don't have these stupid quick clamp-its through out your wiring. You should go thru your harness completely and "hook solder" the wires. I don't care what ppl say nothing beats a great connection w/solder no tap in or clamp-it will give you a good signal. Trust me! I am a aviation electrician on Helicopters. You send me your harness I will go through it for you. I am willing to put money it's a wiring issue "IF" the rest of your harness looks like this. It sounds like your troubleshooting to many area's at once btw. Start simple. Here's one for you don't get overwhelmed by looking at your ride in frustration. Go away and drink a beer(or 4) and then come back after awhile and try again by looking for out of the ordinary. I hope this helps...sorry if it don't. JMO
scottsnissan
Car: 1995 240 sx se
hey man thanks for the post <And no that was what the orginal owner used for his tack.He soddered the rest but not that one (funny)We have been working on this for about 2 weeks or more(since i got car)
But we have found the prob.Finally go the intercooler tested.But before we tested we wanted to clean the inside a lil had some blow by from when guy blew first motor)Used gas poured into inter cooler and to suprise the gas came out from bottom jus a quick as in so there it was the hole time .BAD INTERCOOLER.So thx to all.
Havent found another to conferm it but belive its the prob.WIL update as soon as i get a stock smic or frontmount .Duno dont really care now jus need wheels agin.
scottsnissan
Car: 1995 240 sx se
thx too all trying to help.It was the intercooler and i really app what yall did for me good to see that from here.
I will be doing my own prjector kit and ill do a true write up on what i do and post pics ,Should be by the end of the month,
Turb0wned
ha i told u it was gonna be a leak i got the biggest headachs trying to figure out what was wrong with my car till i found a leak
scottsnissan
Car: 1995 240 sx se
thx man
bentsprocket
I don't know if anyone has said "your welcome" here before I AM SURE they have but I am buzzing drunk right now and I am glad to type that for you. Good luck with the rest of your project. 88,000 nissan freaks one of us is going to get your problem solved....lol.
