compactfean »
https://forums.nicoclub.com/compactfean-u148941.html
Thu May 05, 2011 10:24 am
Sr motors are not known to spin bearings unless there is a loss of oil/pressure. If the knock is loud enough to hear than I almost guarantee it will need crank work done and maybe a new rod. Rods are not machinable nor cost effective to do so. Im not sure how you would get the second part of the oil pan out. Without pulling motor or at least jacking It way up. I just rebuilt my buddies SR and the rod. Knock start one block from his house cruising and rod journal was. 020 out of round and also messed up the main on the crank. To weld/grind the crank was 350 including balance, new rod was 45, new oil pump 150, new rod/main/ thrust bearings (clevite) 100.00$. Definitely not a one day deal. If you have the time you could pull a crankshaft from a infinity g20 at a wrecking yard for cheap but that's alot of work.
