Hijacker »
https://forums.nicoclub.com/hijacker-u9394.html
Mon Apr 14, 2008 5:40 pm
If you're lucky, they got stuck in the head somewhere. If you're unlucky, they made it down the oil return channels and are in the oil pan. I've seen shims fall through and get hit by the crank and do a little damage to the bottom of the cylinder bore before, so be wary when you go hunting for it.
