sr20det rev
Turb0wned
im just about finished with my sr swap hopefully everything goes right from here im waiting for my starter to get here on monday or tuesday and now im just changing the belts extending some wires and im using the stock 240 radiator so i need to get a pipe to conected to the radiator so it should be running early next week, i was just wondering what the sr revs to? also what electric fans is everyone with one using? thanks
bootman
7500rpm I am using a flex-a-lite from autozone
Hijacker
Car: '92 240sx Convertible
'94 F-150
i'm using the auxilary A/C fan. It works fine for me
nismostate
Car: all sorts of motorsports
so what is redline for the sr's. 7500? i've only brought it to 7. want to wait until i get rocker arm stoppers first. im running nismo radiator cap and thermostat. stock clutch fan and rewired the AC fan to a switch. water temp is always below half.
Hijacker
'94 F-150
there's really no point in revving it to 7500. The power curve really begins to decline rapidly a little after 6500. Somewhere between 6500 and 7000 would be the ideal spot to shift. Also, i believe the Silvia's redline is listed as 6900 on the tach, just like ours.
mynismo
tenkawa_akito wrote:there's really no point in revving it to 7500. The power curve really begins to decline rapidly a little after 6500. Somewhere between 6500 and 7000 would be the ideal spot to shift. Also, i believe the Silvia's redline is listed as 6900 on the tach, just like ours.
sr's have power all the way up to 7.5. with my last car i shifted at 7.5 at every shift (sometimes a bit sooner because there was too much power there to shift from 1>2).
silvia tachs redline at 7.5. i don't know what kind of tach you're using or seeing.
JJ240
Car: 95 white 240
a factory SR doesnt...your stock T25 falls off long before 7500.
JJ240
Car: 95 white 240
Guess I should specify S13...no clue what an S14 or S15 powerband looks like.
Hijacker
'94 F-150
yeah. i guess i should have mentioned that too. (the S13 thing)
but i just rechecked the tach thing, and I was mistaken. the redline is at 7500
180crafter
Car: Nissan 240sx
Power curve is dependant on the motor itself... I suggest you dyno it and watch the curve. That will give you the ideal shift points.
Turb0wned
damn i thought the sr rev'd higher my ka was reving at 7500
mynismo
ka's redline at 6.5...
Turb0wned
i feel dumb my ka wasnt reving up to 7500 i was wrong it was reving to 7
dj_lennon_franz
Car: 1992 240sx
S13 redtops redline at 7500 and govern at 7600 on the dot...S14 and S15 blacktops rev to 7000-7200 i think (i know its lower than the redtop stock)
and to the people who think the SR makes power all the way till redline...you are heavily mistaken...the flow rate on a T25 turbo cannot produce the amount of air needed to make power all the way till redline...now if you upgrade the turbo to something a bit bigger like a GT25r or a T3/T4 then yes you will make power till redline...but the T25 begins to fall very short around 6200rpm range...if you dyno yer SR you will notice your powerband peaks at 5500-6500 then begins dropping heavily
f150intally
Stock sr20det, stock t25 turbo... 6200-6400 max
Turb0wned
what do u have done to ur sr?
mynismo
when racing, you keep the car in high gear so it lands right in the juice of the powerband of the next gear.
f150intally
Turb0wned wrote:what do u have done to ur sr?
My Modifications
The torque in the dyno was low because of the 3rd gear pull.
