SR20DET(redtop) Transmission Harness Diagram needed
DriftEmperor88
Car: S14
I got a sr motor with a cut up transmission harness so im trying to put it back together with some plugs off my ka transmission. So can someone give me a diagram of the sr transmission harness?
Hijacker
Car: '92 240sx Convertible
'94 F-150
It's identical to a KA lower harness (trans harness. whatever) The only difference between the two is the signal wire going to the starter selenoid. The SRs use a blade style connector whereas the KAs use a plug.
