blkvrtswp wrote:Some things to try:
1) Try blocking off your BOV and testing again. Without recirculation you are losing metered air when it opens, this makes diagnosing other problems more difficult.
2) Verify you have the correct MAFS - S14 SR will not work, KA24DE will not work, only SR20DET S13 or KA24E will work without ECU modification.
3) Check / set timing
4) Go over boost leaks again - they are a b**** to find sometimes. Your boost gauge should read 15+ on the vacuum side at idle.
5) Make sure you have wastegate, BOV, FPR and boost gauge vacuum lines hooked up correctly.
Good luck!
I'm running stock plumbing so the BOV is recirculated
The maf is indeed an S13 maf. It came with the front clip I bought
Timing is all f*** up. I unplugged the TPS after the car was warm, turned the car off, then back on. Threw the light on, and set it to 15 BTDC. Plugged the TPS back in and it moved it further BTDC. It ran like s*** and had no power, so I moved the CAS back to its original setting. Which is even further BTDC. So...I don't know. I'm just going to keep it where it makes the power
I checked all the piping, the only thing left to check is the intercooler itself. Maybe it got hit going over a bumper or something..
I have my waste gate line coming right off the hot pipe. BOV line is from the nipple under the throttle. FPR is from the 2 top nipples joined in a T. So it actually has 2 vac sources going to the FPR.
I just don't know anymore. I'm really hoping just the intercooler is the problem.
