sr20det redtop Horrible idle
esqueue
I have a redtop with a horrible idle. I've found a video on youtube of someone else car which has the exact idle issue as I am currently experiencing.http://www.youtube.com/watch?v=tUR9xHwtCmI
As far as I know, the swap is completely stock.
Things done so far:Replaced stock KA fuel pump for a walbro 255Replaced all spark plugs for ngk plugs gapped at .030Couldn't set timing correctly.Completely remove and clean intake manifold (some damn coolant line was the reason for the removal) and IACVChecked codes and get 55 A OKCleaned and replaced the MAFTried to adjust idle but wasn't aware that the tps needed to be unplugged.Checked for vacuum leaks and plugged the loose hoses and removed access.
What are your suggestions?
Just for confirmation. On the top of the throttle body there are 2 vacuum lines. The one on the left is capped and the one of the right tees of to the FPR and the BOV. Is this ok or should I separate them and use the capped hose?
Modified by esqueue at 12:16 PM 2/13/2009
redsx13
Car: 93 240sx 03 350z
the one in the vid sounds like a dead cylinder. unplug all you injectors one by one and listen to make sure there is a defference in the idle.
esqueue
The pulse is a little too slow for a dead cylinder. I tried unplugging the injectors one by one and it makes a much quicker miss. Sounds like a WRX after each one is unpluged.
I will take it to someone who can see what's wrong with the timing. I think things are messed up.
redsx13
esqueue wrote:The pulse is a little too slow for a dead cylinder. I tried unplugging the injectors one by one and it makes a much quicker miss. Sounds like a WRX after each one is unpluged.
WRX, lol, i was messing with mine yesterday and i was thinking the same thing.
esqueue
esqueue posted on zilvia.net wrote:I also take back what I said about the timing. Timing with a light does no good. If I put in within range, The car will bog REALLY bad. I don't know what to do anymore. I wonder if some teeth are off.
I just took it to sr20store and he said that the cam teeth were off. I will post If that took care of the problem. Thanks redsx13 for your help.
Modified by esqueue at 7:20 PM 2/13/2009
esqueue
That was the problem. Later.
240dk
Car: 92 Nissan 240sx SR
I think my car has the same issue yours does. I can't set my timing and my idle is weird, how can you tell if the cam teeth are off?
skirodeo7
Car: 2007 Nissan Frontier, 1991 Nissan 240sx
esqueue wrote:
I feel like I have a very similar problem. How did you reset the timing chain on the cams without taking the front cover off to check the crank mark?
redsx13
Wow, i wonder how it got off in the first place?
skirodeo7
redsx13 wrote:Wow, i wonder how it got off in the first place?
If mine is off I imagine it was from after the front cover went on and the chain was dangling off the side of the block. Either that or when I snaked it through the head. Could have easily slackened and caught on the wrong tooth. Stupid mistake, but I'm not sure thats what's happening to me.
240dk
Well i checked mine and my exhaust cam was at 12oclock instead of 1oclock, but It appears I have an aftermarket timing chain and it only has a gold link no black links?? So I have no way of knowing where to exactly position the exhaust cam, any help?
esqueue
Oh s***, I didn't know that this thread was still going on. My chain didn't have any marks so I just took it to a sr20 specialist. He says that he knows how it goes and that was all he said.
I know that when the engine is tdc the dowel pin of the exhaust cam should face up but I don't remember how exactly. Hopefully someone with experience could chime in.
Yeah, no matter what I tried, I couldn't get the timing correct and the car ran horrible.
240dk
so turns out my timing was off, set the timing and put it back together, idles and runs PERFECT, with the exception of when Im driving and I try to get down on it, it will start popping and almost sound like its on 3 cylinders, but if I ease into the throttle it will pick up just fine. Any ideas?
240dk
So I started swapping out coil packs today and turns out coil pack on cylinder four was bad. Car runs perfect now.
esqueue
Well, it's great that you figured out your problem.
redsx13
240dk wrote:So I started swapping out coil packs today and turns out coil pack on cylinder four was bad. Car runs perfect now.
dude, I told you!
redsx13 wrote:the one in the vid sounds like a dead cylinder.
