Newcastle82 »
https://forums.nicoclub.com/newcastle82-u13870.html
Thu Jul 07, 2005 1:41 pm
Alright, so my friend and I just did a compression test on his redtop SR20det... and were astounded by the results. All compression tests were performed with the engine warm at WOT.. here are the results.
#1 - 120-125 psi#2 - 115-120 psi#3 - 115 psi#4 - 115 psi
Now I've used the search button and checked out some other compression test results from similar vehicles, and have seen that about 155 is normal, and 128 is as low as is acceptable.
The car runs good, the turbo still spools hard like the day we got it, but... every now and then, when the engine is warm and at idle, some grey smoke pukes out the tail pipe. It doesn't happen for very long, and not very often, but it does happen. With compression test results this low and the occasional smoke, does anyone have any idea what could be happening? Let us know before we just rebuild it. Thanks!
