Hijacker »
https://forums.nicoclub.com/hijacker-u9394.html
Wed Apr 09, 2008 4:42 am
It's possible to have it 180 degrees out of time. It'll look in time on a light, and you'll be getting spark, but you'll smell excessive fuel and have some weird popping and chugging coming back through the intake tract.
Once you've verified with a light that you're in time, then you can say you're in time. Simply putting the CAS in by the service manual doesn't get you in time, it just gets you close. And if you happened to be off a tooth on the CAS gear (which is possible), you'll find yourself in the realm of either 5 BTDC or 25 BTDC. Neither are fun places to be. Getting my motor rebuild to start took the better part of an evening because of timing issues. My ignitor had been wired in in reverse firing order, so factory installation always put the CAS out by 180 degrees. That always makes for fun issues on a first start.
