sr20det reads low compression help!
Mr HuSTLeR
Car: H2 Hummer, 90 240sx
What could cause a sr20det to read low compression. I found someone who has a sr20det with low compression for $400 w/ turbo. Its comign from Canada but I live in St. Louis, so around $600 for a blown sr20... anyways, what could cause the sr20 to have low compression.
Blown240sx
Car: 1996 240sx
Do you mean lower compression pistons or low compression like reading 100 on a compression meter?
Lower compression pistons allow for more boost safely. Low compression on a stock motor means bad rings, vavles or HG.
S13FASTBACKSR
Car: '92 Fastback SR powered
for that price im sure it has a blown headgasket at the least
da40
Car: 1995 SE 240sx
Mr HuSTLeR wrote:What could cause a sr20det to read low compression. I found someone who has a sr20det with low compression for $400 w/ turbo. Its comign from Canada but I live in St. Louis, so around $600 for a blown sr20... anyways, what could cause the sr20 to have low compression.
weeeell.....what are the numbers??
