sr20det re-built help
enrikegonzalez
Car: 93-240sx-s13/sr20det
i have a sr20det red top and i had a small piston problem (rod stretched and hit the head). well im trying to get z32 pistons and bore my block to a 87 but i need lil more info to keep my 400hp build.
MaximA32
Welcome! Let's see if we can get you some more views/help over in the SR forum.
PyR0NiAk
Car: S13 SR W/ T2 GT3071R .86AR, JWT S4 Cams, 810cc Injectors,Z32 MAF, JWT tuned ECU 87mm 9:1 Compression CP pistons, Manley Rods
Why are you trying to get Z32 pistons when you can just get CP 87mm pistons? (Try www.enjukuracing.com )
You said 400hp. What turbo are you using? What is your fuel setup? What type of tune?
