Mathdes8718 wrote:hey guys I have been looking arround a bit at the setups that most of the guys have on zilvia and nico..
I was wondering if I had to upgrade my injectors to 550cc if I raised the boost up to 13psi on the stock T25?
Should i get an Apexi S-AFC?
And what kind of power should i expect from setup like this?
as of now i have :
3" downpipe3" straight pipe exhaustaftermarket turbo elbow(dont know the brand it came with the motor)FMIC (soon to be installed)and boost at 13lbsVLSD
the car is in storage right now and I can't get it out till the snow melts so i can't get it to any shops to see how much power it puts down to the wheels, but I am curious to see what you guys have to say! thank you!!
you need some sort of engine management, then have it tuned and you will be golden.(do not turn up your boost anymore, if anything run it at 11-12 to be on the safeer side)
btw, if you are worried about your injectors, buy a fuel pressure regulator and up the pressure a little, its not great for your injectors, but its better than running lean.
