SR20DET QuestionS????
Trax07
Car: 1990 SRed 240SX
Ok I have a Redtop sitting in my 89 S13 and the only way i have ever started an engine (had a KAE in it) was a push start. I cant seem to find a wire that comes off the starter to hook it up can anybody help? Thanks in advance...
Edit- and what size is the oil line banjo bolt for the turbo? and does anyone know where to get it?
Modified by Trax07 at 7:56 PM 9/28/2008
Hijacker
Car: '92 240sx Convertible
'94 F-150
The banjo bolt for the oil line is a special restrictor bolt. Not sure on the thread/pitch of it though.
As far as your starter goes, which wire are you missing? There are two that go to the starter a big thick one and a thin black/yellow one.
positron1
Car: Project: 1993 Nissan 240SX Coupe SR
Daily: 2010 Honda Civic Coupe
I've got two of the three turbo line banjo bolts, which one do you need?
Trax07
are you selling? if so ill take both and as for the starter i see the big wire but cant find the other...
positron1
There is a small black harness that plugs onto the small metal tab on the starter near the ground wire bolts. I have the banjo bolts here and here but not the smallest banjo bolt.
Trax07
i got the starter and the sr starts now so all i need is the banjo bolts.
Oil Feed- Banjo BoltWater Feed- Banjo Boltand there is another one?
thanks for helping .... lmk
Hijacker
'94 F-150
There are 3 water bolts They're all the large 19mm head. Two go to the feed line, and one goes to the return line. Then there's the smaller 17mm head oil restrictor bolt for the oil feed line. The part in the turbo is a flare fitting and the return pipe just bolts on with 2 standard M10 bolts.
Since you stated that you need the oil banjo bolt, positron doesn't have what you need unfortunately. The water bolts and the oil bolt are not interchangable
I would think that the banjo bolt would be identical on a 300ZX, though. It might be possible to order one brand new that way. I would call up either Courtesy or West Covina and double check with them. They have access to the JDM catalogue and can cross check it for you.
Trax07
I found them at HeavyThrottle for 30 for both
what i need is the
Oil Feedline Banjo Bolt and the Water or Coolant Feedline Banjo Bolt
Thanks for the help...
Hijacker
'94 F-150
Trax07
Hey bro thanks for the heads up! I dont mean to sound like a prick but are you sure they are the right ones? If so these babies are mine! Let me know and thank you VERY much!
Kalypso
useful thread!
I was looking for the oil banjo.
the thread in my block is worn/stripped. im going to get a custom bolt made thats alittle longer to make use of that extra tread.
crazy but effective.
Modified by Kalypso123 at 8:19 AM 10/3/2008
