sr20det questions
240sx88
Car: 1990 nissan 240 sx
I have been working with my ka24e for a long time, like 1.5 years and it keeps breaking on me, and im fed up with the fixing, i want a sr20det. I want some horsepower but i don't wanna go crazy. Anyone know how much i would need to have fun as far as doin a qaurter mile in 13-15 seconds. Im pretty mechanically inclined and i have quiet a few freinds that have hands on experince with sr's just wonderin how much horse power i could get outta an sr with about 3 grand put into it. ok thanx
keechusmc
Car: 93 rhd 180sx w/ s15 front end
Whell there is alot u can do with 3 grand. But always start with the basics. Do a basic tune up.-FMIC is a must anyware from 300-900 dollars depending on the brand.-Turbo back exhaust (turbo outlet,Downpipe,Strait pipe(or cat), And exhaust system(My fav one is the Blitz Nur Spec for 180sx or 240)-The stock S13 turbo is pretty gutless so i recommend upgrading to either a used s14 turbo(if u are short on cash), or a new s15 turbo can range from 750-900 dollars new.For 350hp+ i like hks gt-rs turbo.-If your boosting above 17psi i recommend a new head gasket.-Fuel wise your gonna want to upgrade your fuel pump. Walbro 255 is cheap and effective. But you get what you pay for so i would go Nismo or Tomei. (most aftermarket fuel pumps will have great wining noise .-Fuel injectors is an easy choice I chose nismo 555cc injectors that are plug and play (no splicing wires ex. sard).-But with all of this your going to need your ecu retuned or your gonna need management.-If you can get a Z32 AFM (huge difference in power/ response Get your ecu tuned though)
All of these items probially add up to more than 3k but i will show u what i am running.
-Sr20det (redtop)-Blitz FMIC-Apexi S14 w/ Z32 AFM suction kit (Intake)-S14 Turbo-Trust Turbo extension-Blitz downpipe-MR strait pipe-RS-R catback-HKS BOV-NISMO 555 injectors-NISMO Fuel pump-NISMO Coppermix Clutch/Flywheel kit (rs420)-Yashio Factory coilpack +-Blitz Boost Controller (running 1.1 low - 1.3 high bar or boost)-Tomei 1.5 way LSD-HKS 1.2mm Headgasket-E-5 ecu Tuned by Rio Car AV Square/garage (I live in Japan )7700 rev limit, no speed limit, upgraded fuel maps
More than enough power for a gutted 180sx.
DRIFTINIZ
how loud is the whine that is associated with the upgraded fuel pump.....i have a walbro 255.......does it go away when the engine gets warm?? also, how many psi are you running on your setup?
DRIFTINIZ
haha, shoulda read more.....answered the boost question, but still curious bout the fuel pump whine......later!
Blown240sx
Car: 1996 240sx
If your looking to run 13-15 in the quarter yo dont need to spend that much money like the guy above has. Ive seen a Stock SR with a FMIC VLSD Fuel Pump and Upgraded clutch run 13.8 in th 1/4.
240sx88
alright thanx appreciate it, one question, my car that i have now is russted ont he bottom bad, my plan is tobuy a new 240sx later and take the engine back out and to a complete upgrade to put as much power as i can in it. My question is this:I know the sr motor is tuned to use the 89-90 gauge cluster, which one do i need and whish model of the 24osx is that gauge cluster stock??
wildacexxx
Car: 2002 Q45 nav sport
i believe that sr's need a 91-94 cluster (dohc). any model 240sx cluster should work. they're basically all the same with the exception of digital coupe ones that suck and never light up . if your going to get a new chassis i suggest u do before u get the sr. no point in doing the work twice.
Blown240sx
Car: 1996 240sx
You have to use a DOHC gauge cluster for it to work.
240sx88
Wouls a 89-90 gauge cluster work at all.like it is just off the exact rpm or will it not work at all??
DRIFTINIZ
what kinda noise does the upgraded fuel pump make???? how loud is it?
hazw8st
DRIFTINIZ wrote:what kinda noise does the upgraded fuel pump make???? how loud is it?
If the fuel pump is bolted straight to the body without rubber grommets, it makes a very loud noise. Once the pump is isolated using grommets, it makes less noise.
