SR20DET questions
sprite
Hello, I'm about to buy a S13 SR20DET and I have a couple of questions to ask before I buy it. I want to replace the clutch and I heard the 1989 Maxima Clutch kits work. Is the only year maxima clutch's that work, or do other year maxima clutch's work?
Also when doing the wiring what all do I need to wire the main engine harness? Do you I need the S13 SR20DET main engine only? Or the S13 SR20DET main engine harness, and the S14 KA24DE harness also together?
Also after buying my intercooler will I need any hot pipes or cold pipes to connect the intercooler to the motor, or can a shop make them?
Thank you for answering these.
Nismo_Freak
Car: 89 Nissan 240SX
You will need an S13 intercooler kit, S13 hotpipe, and you will need a few connectors off of the KA harness for the wiring.
