SR20det question?
HI NRG
Hey guys I am finally looking to get an SR swap done to my 92' 240sx.I was wondering if the transmission from the KA engine will bolt up to the SR engine or will I have to get a transmission off a SR engine?
compression
The KA24DE trans will work, 5th gear is a little taller, but other than that, all the other gears are the same ratio.
912.0turbo
Ditto.....just the bellhousings are different,it wont bolt right up.
HI NRG
do they make an adapter plate for the bell housing or were can I purchase a bell housing that will fit the SR engine
msaskin
Car: cars, computers, skiing, mountain biking
Buy the bell housing off of an SR20 transmission.
If you order a motorset to do your swap you'll get a transmission anyhow.
~matt
HI NRG
Well I was thinking about getting the swap from japanstarmotor.com....give some info if you guys ever heard of this company. I think on there ad they say that they don't have the transmission with the engine.
912.0turbo
You would be better off ordering from one of our sponsors. I never heard that company but then again maybe somebody else has.
dj_lennon_franz
Car: 1992 240sx
912.0turbo wrote:You would be better off ordering from one of our sponsors. I never heard that company but then again maybe somebody else has.
DO NOT ORDER JUST A MOTOR SET!!! YOU WILL BE MISSING TONS OF STUFF AND IT WILL COST YOU IF NOT THE SAME BUT MAYBE MORE THAN A CLIP!!!
for yer first swap its well advised to get a front clip...you will have EVERYTHING you need for the swap...and u will use just about everything from the clip minus the power steering stuff and a few other odds and ends
