SR20det PSI
Roc
Car: Ae86
I Skimmed through the faqs, but what is the max psi I can set on my s13 sr20det blacktop? sorry Iver heard around 17 but you know thats by ear.x
homeslicej2
Car: 1990 Nissan 240SX S13 SR'd hatch
depends on your setup (stock turbo or upgrade, smic or fmic, stock injectors or upgrade, stock MAF or upgrade, etc.) a good search would have turned a lot of this up. Check the stickies in the SR forum. Oh, I wouldn't run 17 PSI on a stock headgasket either. Depends on your tuning to and...a lot of stuff man. People would need to know what you're shooting for and what you're using too.
Roc
Car: Ae86
everything is stock besides the bov, fmic, down pipe and exhaust. i would like to be able to push about 12 psi.
Modified by Roc at 7:18 PM 4/7/2007
killablue240
Car: sr powered s13 coupe, 1991 twin turbo 300zx
i have high volume fuel pump, fmic, full exhaust and i run 14 daily for about a year now.
Roc
Car: Ae86
oh and i do have a new walbro fuel pump then i can prolly run around 12 then im getting a safc off my buddy. he owes me cash but this will work.
homeslicej2
12 PSI should be fine then with that stuff. if you have the stock T25, that's as high as I would run. The T25 runs out of steam (it's no longer efficient) b/t 13-15 PSI.
Roc
Car: Ae86
Im going to look for another turbo also.. my buddy i think suggested gt35rs28 i think he said. or it was gt35rs
SpeedRacer1
Car: 1990 240SX, G35
Stock boost pressure on an S13 SR is 11 psi, 12 would be fine.
DrifterProdigy85
Car: 1989 Nissan 240sx (Zenki Onevia)
T25 and SMIC...12psiT25 and FMIC...14psiT28 and FMIC...12psi
Headgasket blows from engine conditions, not boost alone. Ive been running 20psi on the stocker for over a year now and everything is fine. Im even gonna be putting a 50 shot of nitrous to it soon.
Roc
Car: Ae86
I thought stock boost is about 7psi ? and I have a black top it comes with a t25 factory correct?
adrianfromthecastle
Car: 1992 Nissan 240sx
Roc wrote:I thought stock boost is about 7psi ? and I have a black top it comes with a t25 factory correct?
yes and yes
kamikazestorm420
stock boost is 7 with the solenoid disconnected.
with it connected is 10 IIRC or 11 psi
Roc
Car: Ae86
ok awesome. I just picked up a avc-r im prolly going to set it up for around 12 psi, how much of a gain you think i will receive from 7
homeslicej2
Wait, solenoid? I'm confused. I thought the stock PSI was 7 no matter what. What solenoid are you refering to?
kamikazestorm420
homeslicej2 wrote:Wait, solenoid? I'm confused. I thought the stock PSI was 7 no matter what. What solenoid are you refering to?
the boost control solenoid attached to the ignitor plate. i didnt know till i read this thread either.zerothread?id=224755
redtop91
Car: ↑ ↑ ↓ ↓ ← → ← → B A Start
kamikazestorm420 wrote:stock boost is 7 with the solenoid disconnected.
Incorrect. No one ever uses the solenoid and my boost solenoidless is 10 psi. The 7 PSI SR is a factory number. The wastegate spring on the T25 sucks balls. All SR's either over or underboost.
