blueballa wrote:so i can use my sohc lines from the chassis to the dryer, but the one that goes around the engine block to the back of the compressor needs to be custom made? the sr end links, do those connect to the sr compressor? or are those a part of the custom line you have to make? which line needs to be remade?
and for the ps, both of the high - low lines connect to the rack? what bout the line that goes from the resovior to the rack? is that still the same? so theres three connections to the rack?
both ac lines on the sr compressor will need to be custom made but you will need to make sure your compressor works first and the lines plus recharge will be around 400 bucks if you know how to recharge it yourself you could save some money.
on mine there are sub lines that the reservoir hooks into and the high line runs to the rack ......
