sr20det project finished (oil ????)
rocwyld06
Car: tuning, sports, cars, tv, etc
whats the best weight oil to use in the sr20det?
10w3010w4020w50
msaskin
Car: cars, computers, skiing, mountain biking
I run 10w30 in colder weather and 15w50 in the summer.
All mobil 1.
~matt
quiksilvia
Car: 95 s14 se
i think i use 10 30
jammer
Car: cars, rock, computers
It is advisable to follow the manufacturers book, but if in doubt go with 5w 30. It's a great medium and good for all year, summer winter etc, that is if winter applies to you. Make sure you change your oil every 70 hours of run time on your engine.
jammer
:ylsuper
DoriftoMania
Car: car
if you just did the sr20det swap use mobile 1 drive clean 20w50 change oil within 500 miles of driving for the first time.next use same grade of oil for 2nd 800 miles and 3rd 1500 miles oil changes.after the break-in motor you can use full synthelic oil mobile 1 synthelic 10w30 everday but change oil as often every 2000 miles.
:: orion ::
Car: '96 240SX, with KA-T @ 12psi...
SR20s typically DO NOT need any break in..remember, they are used junkyard motors we buy from overseas. No need to take special precaution, or do any break in.
Maybe one oil change soon after the swap to remove any gunk, but that's all...
Also, it's a waste to change Mobil 1 so often...look around the web, read some test data.
A guy did a test where he sent 1/4 quart of Mobil 1 to an independent lab (Blackstone Labs IIRC...) every 1000 miles, and the used oil tested better than dino oil and as good as new Mobil 1 for close to ~18,000 miles.
That's a filter change evey 3000 miles, and topping off the oil as needed (basically replacing the 1/4 quart that he drained for testing).
FYI...
- Brian
xatracing
Car: 240 bandit
we recommend 500 miles than oil change. That should suffice.
book-ends
Car: ???? Nissan 240SX coupe S13
rocwyld06,
You stated that the SR20DET project is finished. Do you mean that you just swaped in a junk yard engine from Japan; or did you actually take the time to pull it apart, redo the bottom end, new valvetrain ect?
If the latter, then follow the new motor break in rules, otherwise I agree with jammer......5w30.
91GTS-t
Car: CARS
Just a question...... How much are you guys paying for engines from Japan?? Just curious.
quiksilvia
Car: 95 s14 se
front clips range from 1500 to 5000 depending on the motor and condition, i paid 2k for my redtop front clip
91GTS-t
Car: CARS
Alright, just curious about that. I just picked up another 91 GTS-t for $500. Just gonna strip it and junk what is left. Im looking at buying a friends 93 Silvia too.
fallen180sx
Car: 90 Sil80
wutup quicksilvia! its underasilhouette.. hey i just wanted to say heres a site with cheap front clips.. might wanna check it out.http://www.flashoptions.com
msaskin
fallen180sx wrote:wutup quicksilvia! its underasilhouette.. hey i just wanted to say heres a site with cheap front clips.. might wanna check it out.http://www.flashoptions.com
Have you ever heard the nightmares of people who have ordered from flashoptions?
The prices are cheap, but then again, you never get anything for your money.
~matt
91GTS-t
Car: CARS
Anybody lookin for parts let me know and Ill see what I can do. Email me at [email protected] Im in the states right now but will be going back to Japan in September. Let me know.
91GTS-t
Car: CARS
msaskin wrote:Have you ever heard the nightmares of people who have ordered from flashoptions?
~matt
That picture they have on the site looks like trash. That front end is nasty! You can get much better.
SRdave240
back on topic...
I use synthetic valvoline synpower 5w-40
