Turb0wned »
https://forums.nicoclub.com/turb0wned-u8477.html
Sun Dec 04, 2005 2:54 pm
i bought an s14 SE, drove it for 2 weeks then finally had all the parts new front mount and got my ecu back from enthapy, so i took my ka out made put my sr in made the car 5 spd re did my wiring harness plugged it all up and went to crank it, motor turns over but wont start, so i think maybe theres no spark found out there was so, maybe no fuel pressure but the fuel line had fuel in it, so then i maybe no injector pulse....? i put gas into each cylinder and it started right up and didnt shut off so there has to be injector pulse if not it would turn off after the gas i poured in burned... any idea's of what it can be? only way i can get the car to turn on is by putting has into each cylinder, i was thinkin maybe the fuel pump? but why would it just go bad out of no where u know.... i didnt have time today to take out the fuel pump and put it to the battery to see if it works ill have to do it tomorrow, its a stock fuel pump i forgot to take my walbro out my other car before they took it i will be buying a another before i boost at all though but it should still run with a stock fuel pump because i have done it before.... can anyone help me, any ideas at all? thanks
Modified by Turb0wned at 11:25 PM 12/4/2005
