listen for the noise at the peak of the rev's
WTF IS THAT, The turbo builds solid boost, steady 7psi.
Gasket? I sprayed soapy water EVERYWHERE and found nothing. no leaks!? could it be the exhaust manifold? the soapy water just boils away when sprayed on it so Its hard to rule that out?!
idk its annoying as f***! give me some helpful advice
