glacier985 »
https://forums.nicoclub.com/glacier985-u8820.html
Sat Jul 15, 2006 11:09 am
Okay, lets see. First off, car cuts out anywhere from 5500rpm to 6500rpm, somewhat random. So we figured the MAFS was maxing out. So a daughterboard was installed and a tune made for 555cc injectors and a q45 mafs was put on the chips. This fixed nothing (and the jumper was moved from CJ1 to CJ2). So more and more tunes were tried, nothing fixed anything. So daughterboard was removed and the car still ran, didnt cut out until 7k rpm, so we are like wtf??? So come to the next day and the car is cutting out a 5500-6500rpm again.
A new tune is tried for the stock MAFS and 555cc injectors, still the same. So we begin to suspect something else. The MAFS wiring, so with the car running the MAFS was disconnected, but to are amazement the car still ran the same. So now we are really, really confused. So my buddy, who owns the car begins to search for a cut wire, short, anything. But finds nothing, and decides to cut the MAFS wires at the ECU and yet the car still runs the same. Nothing seems to fix the problem. So the wires are reconnected and a new ground is install for the MAFS. This does nothing either, so now we come to this point, wtf if wrong with the car, it should not run at all with the MAFS disconnected and 555cc injectors with no tuning whatsoever.
Any Ideas??
