SR20DET Problem please help
mfroelich
Car: 1993 240sx hatch
My sr ran perfectly but yesterday i span out and when i stopped i started the car back up and it would barely go over 1000 rpms when i got to a good place to stop it cut off and would start back up but immediately bog down and cut off. I checked for fuel problems but that wasnt it the spark plugs were flooded so i changed them and it still wouldnt start then i checked the timing and that was fine too. If anyone knows what my problem might be please tell me Thanks, Matt
sbs
Car: 1995 240
if you spun out? Then check your batt cables and your ground cables.
comatoseculture
Car: 1990 240SX coupe. Currently running on Megasquirt.
Did you keep/have the clutch all the way in while spinning/out of control?
mfroelich
nah i didnt have the clutch pedal in. But i didnt roll backwards in gear if thats what your wondering.
