kryton »
https://forums.nicoclub.com/kryton-u29168.html
Sat May 28, 2005 4:29 am
Hello,I'm new to the forums, but I need some help. I have an 89 240sx with the sr20det redtop in it. It's been in the car for about 2 years but this is my second motor. The problem is I can't get the car to start. It has spark, has fuel but just sits there and cranks. I did manage to get it started once and it ran for only about 7 mins, we took it up the road and it was running really rich. Then it just died on the road, couldn't start it with the key, they only way we could get it running was to let it roll back down the hill and pop the clutch. We got it back to the garage and then it wouldn't start period, just cranks. I tried with the stock injectors, stock maf and stock ecu. I also tired with my 550 injectors tuned eproms ecu and z32 maf. They all did the same thing. I checked the timing, it didn't seem to be off. however we took the spark plugs out and they are covered with fuel since the engine is flooded. Next I took the fuel rail off to discover that the injectors are all firing at the same time, now i haven't work on cars for that long but i know thats not normal. The last attempt i made was to wire the injectors straight off the ecu and bypass the factory wiring all together, still the same problem so i'm stumped. could I maybe have a bad CAS? Any help would be greatly appreciated guys because at this point i'm seriously just thinkin about selling the car.Thank you
