Justin35ll »
https://forums.nicoclub.com/justin35ll-u118020.html
Wed Nov 19, 2008 12:43 pm
Well, you pretty much can install it right off the pallet, but I would recommend getting a gasket set and replacing them and cleaning the motor.It's not neccessary, but just to make sure it will run properly and be sealed correctly I'm in the process of doing mine.Also I'm replacing all the coolant lines and other misc. vacuum lines because most of them are rotted out. Also not necessary
Also I'll be installing upgraded engine mounts, radiator, fans, and possibly belts while I'm at it too
That's all I'm doing before I throw the motor in the car. Then once the motor is in I'll upgrade the fmic, and all the good stuff.
If you're not willing to spend a little extra to make the engine run good then why did you spend a lot of money to get it and put it in the car?The things I mentioned should probably be done
