Sr20det Power Capabilities
badass240
Car: 89 240sx
hey all,
i have a 91 240sx with a sr20det swap on 6psi. i was wondering how much can the sr20 motor with stock interials hold for power. what is safe for me to run without having to worrie about blowing the motor.
thanks.
shift_SRDETuser
Car: 1996 Nissan 240SX SE
Enough Power to change the gravitational pull of the Earth upon its axis and travel back in time......
J240sx
Car: 89 240sx
lol, as far as internals the sr20 is very capable for holding a good amount of power safely. If your running the t25 I believe that runs out of power around 13psi. Everyone's going to tell you to search.
badass240
Car: 89 240sx
J240sx wrote:lol, as far as internals the sr20 is very capable for holding a good amount of power safely. If your running the t25 I believe that runs out of power around 13psi. Everyone's going to tell you to search.
thanks for your reply, but im puting in a t3/t4 and 550cc injectors. that should beable to make some power but how much power will it hold safely like 300 400 500 hp??
supreamS14
Car: 96 240sx S13-blacktop Sr20deT
The sweet spot is 400whp! Some hit 500+whp without blowing anything.
shift_SRDETuser
supreamS14 wrote:The sweet spot is 400whp! Some hit 500+whp without blowing anything.
all about tuning a nice standalone and you can make some nice power on stock srs
badass240
Car: 89 240sx
ok so 400hp do i need any thing to hit 400hp or will i have to change a few things. things like head gasket and head studs or i can get 400hp without them?
shift_SRDETuser
badass240 wrote:ok so 400hp do i need any thing to hit 400hp or will i have to change a few things. things like head gasket and head studs or i can get 400hp without them?
the stock gasket is paper and metal for added insurance anything over 300 whp -- it would be good to get an apexi headgasket and some arp headstuds....
badass240
Car: 89 240sx
ok i got it 300 is safe with stock headgasket anymore will need the upgrades thanks man.
TKOcrewSR
Car: 1990 nissan 240sx
no offense not one to flame but search and learn about your car its been covered.
Justin35ll
Car: s13 coupe sr20det
Just wondering.. I have arp headstuds I installed brand new with a new oem gasket, if I were to upgrade to a metal gasket later on. Is it possible to reuse the arp or will I have to buy a new set?
shift_SRDETuser
arp head studs are good up to 2500 psi. I doubt you could really ever crack or break them? your turbo would blow up to little pieces before your head would pop off...
supreamS14
shift_SRDETuser wrote:arp head studs are good up to 2500 psi. I doubt you could really ever crack or break them? your turbo would blow up to little pieces before your head would pop off...
I broke 1 torquing from 80 to 90 ft lbs. Maby it was a defective stud.
aaronbeisel
Car: 91' Nissan 240sx
Depends on how you drive it and what you are doing to it.
badass240
Car: 89 240sx
aaronbeisel wrote:Depends on how you drive it and what you are doing to it.
Drag/Street racing it maybe drive in to work once or twice a week.
Koshin
Car: JP'd out Y32 Nissan Gloria GTU
750 hp '87 Buick Grand National
'63 Chevy Impala SS 327/4 speed
11 whp
tunermt
Car: s13 ka-t running AEM EMS v1, Gallant VR4 Running AEM EMSv2, S2k waiting for the Haltech
I was recently linked to this thread by someone that had some SR20 questions so i Thought i'd post some details here incase anyone else who finds this thread in the future has some extra information.
If you want a detailed look into the SR20 and path of least resistance for making reliable HP check out this article: https://www.brewedmotorsports.com/sr20det-tuning-guide/
Simply put the SR20 is a solid engine, weak points are:
-oem non MLS head gasket (older non S15)
-oem heads/ports do not flow that good from the factory (port work makes a BIG difference).
-oem valvetrain design is not ideal (check out the link above for easy solutions to this by using dual guided shims)
I regularly have to tune SR engines with a huge range of mods so i've seen all sorts of parts combinations in action over the past 16 years. Up to 400whp the stock bottom end is decently reliable. You can make up to 500whp BUT that is pushing the limits of the stock bottom end and it will end up bending a stock rod at 500+.
-100% stock engine (stock cams/valvetrain/ports/head gasket) Limited to roughly 400hp, cams/head work will help the engine make good power with less boost/stress on the bottom end.
-MLS head gasket, cams/springs/retainers with stock bottom end will make 400-500hp much more efficiently. Using the MLS will also allow you to run a little more boost with a high octane fuel like E85 or other ethanol blends.
-fully built with OEM sleeves: The OEM SR20det sleeves are good to roughly 550-600hp above that you should be running Darton mid sleeves to keep the engine reliable at high power/high boost.
My personal S14 SR20det:
