pampadori wrote:are you reaching 12psi in first gear at 3500 rpm? this is pretty normal. in 3rd and up, you should hit 12psi a lot sooner. 2800rpm or 3000 or so.slugish? try shifting at 6500 rpm and check the timing.
to check timing, engine must be warm. shut off car. unplug tps, restart, set idle to 700rpm. set timing to 15 to 117 degrees advance. turn off car, re plug up the tps. go test drive.shaun
pampadori wrote: when you let the clutch out to launch the rpms are going to drop. unless you spin the tires. i'm kinda confused. maybe you were expecting something more fromt he sr swap. but 250 hp is more then the ka, but you should only tell a difference from 3000 and up. maybe a loss under 3000. i'm confused...shaun
SrS13 wrote:What causes that loss under 3000? is that what lag is?? would that also be because I am running almost no catback because the stock 240sx pipping is even conneted all the way???
Thanks for all the help
SrS13 wrote:Also before I forget I cannot keep my rpms up when I am reving before my launch.
For example: If I am reving up to 3000 when I launch my rpms will drop to like 2000. As soon as I step on the throttle and start to release the clutch my rpms drop. Am I doing something wrong or is there a problem with the car????
yes i ment to say my stock 240sx piping is not connected all the way it is halfway connected. But I feel that loss when I am not running a catback at all even more, when I am running open downpipe. Why is that???Drakon wrote:And i dont think anyone gets it. DO you have the stock 240 exhaust? cause that will cause alot of slugish feeling like the other guys said because its drastically restricting the airflow out of ur engine.
