SR20det parts needed for install
goixiz
Car: Cycling and cars
Hello,Ive just got my half cut and am planning to do the install next week. The following are the parts i need to complete my install.
Please recommend what i can purchase and install. A place or phone number if available is greatly appreciated. I prefer bolt on components over performance.My car is a 1990 240sx se hatchback
I need the following
1. Radiator - something similar or slightly better than stock that potentially can use an electric fan 2. Radiator hoses3. Belts - PS, AC an Alternator4. thermostat and gasket5. Spark plugs (need part number)6. Oil Filter (need part number)7. ACT clutch kit - Stage II8. Water Pump9 Fuel Filter
240_Keyy
Car: '90 240 Fastback
check the SR Swap info page at heavy throttle, the majority of these part numbers should be there for you. Most of the stuff carries over from the SR20DE Sentra SE-R
NeedCAforS13
Car: CA swapped S13 coupe
"Most of the stuff carries over from the SR20DE Sentra SE-R"
no it doesn't...i don't think :D
correct me if i'm wrong...
Sean
240_Keyy
http://srswap.com/html/info/faq_partinter.htm
lol, well lots of stuff carries over from the sentra and the 300zx :D
BuudWeizErr
The oil filter part number is xxxxx-53J00. If you say you need the "53J00" filter at a Nissan dealership, they'll know what you mean. It's for a 91 B13 Sentra SE-R (SR20DE). Radiator, get a Koyo, and maybe cooling performer radiator hoses. http://www.phase2motortrend.com carries both.
